ohioriverat
Thread starter- Joined
- Aug 7, 2011
- 115
Please help anyone, i have a 2000 model 70 hp johnson that has ran good all summer until a few weeks ago. It would run for about 6 minutes at wot and then immediately shut down to around 3k rpm's, now it will start and idle but when i try to take off it rev's up for 1 second and then goes to what i think is SLOW mode!! i have unhooked the tan wire from pp and ran it on river with same results, unhooked the yellow wires to regulator and same thing. i have spark on all 3 cylinders, 120# compression and a new vro installed by dealer 2 months ago. my stator wires br/br.yellow are reading high// 800-850 ohms but the dealer said it was probably my pp again. I have a dva meter but not sure how to test this model engine!!
Does my stator have high and low like mercury?????
Can i bypass the SLOW or is it built into the pp??
what about shift interrupt switch bypass?
I tried pumping bulb when it acted up but it was hard and made no diff.
THANKS for any help!!! i have another new pp ordered and will be here tomorrow but i still feel i am missing something about this model?!! the dealer said he HATES this motor and is not much help..thanks again fellow boaters..
