2000 70hp Johnson quit
halibutts
Maybe my first post was too lengthy.
Engine only shows life directly after pumping up the fuel bulb, then doesn't stay running. :confused:
Honorary Supreme Mariner
What happens when an assistanrt operates the manual pump ?-----What happens when you push in the key ( 2 stroke engine ) momentarily ?
halibutts
Just had my assistant pump while I turned it over. It fired up for about 5 seconds and then no more. He couldn't keep the bulb hard and the carbs seem to be pretty much covered with fuel.
