Chuck Gibson
- Joined
- Apr 13, 2005
- 123
My model number is J50PLSSM
My VRO unit has bit the dust. It started surging really bad going across the water. I pulled the cover and noticed that gas is leaking out of it. I was planning on replacing the VRO with a fuel pump and mixing my own gas anyway, so now would be the ideal time. Pulling up OEM part numbers, I found that the motor uses pt# 0438557. When I pull that part up on the website that has it listed, it shows the part is for years 1990-96. It also has three nipples when I only need two. I have found other fuel pumps that look like what I need like pt# 0438556 and 0438559. These pumps only have two nipples.
What is the difference in these fuel pumps? If I end up with one that has three nipples, can I just plug the one that is for vaccum?
