2001 johnson ocean pro losing 2 of 4 cylinders on plane,,HELP?
jacksmith2009
all in the title.....idles fine, when full throttle and on plane, 2 of 4 cylinders are lost. Any info? EASY troubleshooting techniques...anything helpful would be great.
THANK YOU FOR YOUR TIME AND INPUT/S.....
JACK
tashasdaddy
Re: 2001 johnson ocean pro losing 2 of 4 cylinders on plane,,HELP?
could be coil, as 2 cylinders run off one coil.
kenmyfam
I'm on board with the coil as well.
Welcome to iboats.
Faztbullet
If you are losing 2 cylinders opposite each other (say 1 & 2) it could be a coil as this is 2 seperate coils molded together but if its a bank (say 1 & 3)are dropping its possible stator or pack problem.
jonesg
Does it have a shift interrupt switch, if yes , disconnect it and test run it.
If no... try swapping coils and see if the problem follows the coil.
If the problem stays put then I'd look at the power pack and stator.
If the insulation is melting and dripping down from the stator, thats a good sign its gone south.
Otherwise you need a peak reading meter and the shop manual to do the tests that will pinpoint the trouble .
www.outboardbooks.com
Get the meter off ebay $75.
Scroll down,
http://cgi.ebay.com/ebaymotors/Mari...tZMotors_Automotive_Tools?hash=item35a473afc8
tashasdaddy
what HP?
ezeke
Sounds like S.L.O.W. is activating; check your cooling system.
tashasdaddy
good call ezeke. could be, but i thought that just limits rpms, not kill cylinders.
Chris1956
Honorary Supreme Mariner
The S.L.O.W. systems limits RPM by killing the spark to one bank of cylinders. it is controlled by the temp sensor on one of the heads.
reeldutch
i could be wrong but i tought that slow retarded the timing on all cylinders.
