2001 Yamaha 50hp tlrz 2 stroke with prime start system starts and dies
99yam40
I will get the new CDI Box on Tuesday and check all the settings again and also check the timing setting needed to run the motor before I install the new CDI Box. Should know if the problem is fixed sometime on Wednesday. Thanks, Tom
hopefully you have a timing light to check this
tdave
Using timing light in the bright Texas sunlight I read 2-4 degrees BTDC is where I can get the motor to run and stay running. This reading was done before changing out the CDI Box. The new box was not exactly plug and play because the metal pointer, needle arrow on the new CDI Box was flat and hit the hex nut as the throttle linkage was moved. Was able to use the old pointer by doing minor filing to the square bolt hole.
Installed new CDI Box and double checked all settings and fired the engine up. Engine fired right up to about 2000 rpm and after about a minute slowed down to about 800 RPM. It ran for about another minute then started to misfire or chirp every 3-4 seconds. Discovered the fuel bulb will not stay primed/firm (new issue since last time). Disconnected the new gas hose from motor and squeezed the bulb and it stayed hard/firm. Engine will stay running if you keep squeezing the bulb. So now I have an issue with what sounds like backfire and fuel pressure to the Carbs. Fuel pump was new last year. Could vacuum lines be an issue, I do not see much about them in my repair manual.
99yam40
sounds like a lean sneeze.
and pump is not doing its job if pumping the primer bulb helps.
check to make sure pump is still good,
and the idle jets/passages are feeding the fuel needed for each cylinder
tdave
I replaced the fuel pump today started the engine. It ran fine, idled down as it should and ran for some 35-40 seconds before some chirping, misfire noises and it died. I pulled the fuel line coming out of the pump and cranked the engine over and observed the amount of fuel it was pumping. It did not appear as a steady stream but somewhat bubbly and not enough to run through 3 carbs. Will try to bypass the fuel pump and get gas directly to carbs tomorrow.
99yam40
there is a chance you have a leak between the pump and fuel tank allowing air to be sucked in,.
But then the pump runs off of the #3 crankcase so it just pulses ,so does not run a steady stream.
rereading your other post, if pumping the primer bulb helps then look for an air leak between the bulb and pump.
good chance at filter housing oring or quick disconnect or one of the other hose fittings
99yam40
you have not reported what the timing is doing with the new CDI box installed.
at start up my C40TLRX shows around 5 BTDC and idles high.
once warmed up it drops back to 7 ATDC.
what does yours show?
also post up a pic of your new CDI box hooked up.
I am not following the problem with the wiper arm hitting the nut.
Maybe you did not buy an OEM CDI box,
what did you get?
and I have no idea how by passing the pump will get fuel to the carbs, something has to pressure up the fuel lines.
99yam40
did you follow the link and sync procedure in your service manual after you put the carbs back on?
all 3 carbs throttle plates need to completely closed and tied together so all are contributing to the idle the same.
(not just set at idle position)
also the timing is part of the procedure
99yam40
any updates yet on your motor
link and sync and idle timing is very important
tdave
Been raining here on and off for the past few days but will get back to checking things. Plan on replacing fuel lines and clamps to begin with.
maineiac5586
I have a oem used cdi box on ebay from a 2000 40 hp 3 cylinder in good working condition
Item number 186185638248
tdave
Well, I got tired of swapping out parts and took the boat to a Yamaha dealer. They said it would be about 2 weeks and $149 an hour. They called after the 2nd day and said they needed to replace fuel lines, bulb and fittings before they could go any further and of course everything had to be Yamaha. I received a call this morning from the dealer saying they cleaned the carbs and the chirp went away but the issue was with the plastic, 6 gallon fuel tank. The dealer stated I could bring them another fuel tank or they had new ones for $100. Since I wanted to make sure this motor ran correctly before I picked it up I opted for the new OEM approved Yamaha tank.
I am waiting for them to call and say they ran it with the new tank and all is well. Repair cost-$834. By the way my fuel tank was new from Walmart this year and fittings were from old tank. Will update when I get a chance to drop it in the water. Tom
tdave
Picked the boat up yesterday and I had them start and run the motor for some 30 minutes. It ran just fine with no issues. When I asked what the issue was the mechanic said he wasn't sure but said it was a vacuum issue and he pointed out all the parts he had replaced which included: Mini 10 Micron water/fuel filter, 033470-10MP Tank CNCTR Y, Fuel Pipe Comp, Element Filter, Filter Assy, Filter Assy, Fuel Pump Assy, Gasket, Fuel Pump 1,Ultra Gas Tank ^ Gal EPA.
He said this one had him scratching his head and it probably was a combination of issues causing the motor to not stay running. Will take it to the lake in about 2 weeks for a test run and hopefully some Talapia bow fishing. Thanks everyone for your suggestions and help.
99yam40
Very disappointing that they could not pinpoint what the problem was.
in those 30 minuets did they run it in gear with a load on the motor/prop?
I would be trying it out a lot sooner to see if they actually fixed it.
tdave
I had them test it with the prop on in forward and reverse in their large tank. I also asked about warranty and was told 90 days so we will see.
99yam40
changing out the fuel tank and line should have been simple to eliminate those, by just hooking up a known working one without you having to buy new ones . If that did not correct the problem, look at other things.
does not sound like they did much testing just replaced a bunch of parts
but then if they gave you your tank back you could always hook it back up to see if the problem shows back up.
I just have the need to know what the problem was that caused it.
guessing drives me crazy.
looks like they just worked on the fuel delivery, so at least you know that much
tdave
Took the boat out last week and the motor ran perfectly. It idled down for trolling and never missed a beat. Happy boater.
