2002 searay 182 w/4.3 merc (coming out of the hole)
wrvdb
This does not happen every time, but lately when the boat is at idle and I give it gas it sputters for a few seconds prior to going. Then runs fine at cruising speed. Any ideas? I am puzzled. Thanks
This boat has a carburetor on it and has no problems starting.
BAproject
Re: 2002 searay 182 w/4.3 merc (coming out of the hole)
clog or water in the fuel system somewhere? Check your plugs as well
OldNBold51
Check and see if your accelerator pump is working. You should have a visible stream of fuel squirting when you throttle up quickly (pump the throttle). No squirt results in a lean condition (stumble) when the throttle is opened quickly.
jkust
What maintainance has been done to it? Have you had your 100 hour service?
wrvdb
I just bought the boat this year and have put about 60 hours on it so i can not say what maintenance has been done. I really need to get the manual for this engine. Does anyone have an electronic copy. Looks like the link has been removed? Thanks
