I hooked up an external fuel tank with primer bulb line directly to pump and it did same thing. I will look at electrical. ThanksThere are a number of common problems that can cause that difficulty:
Blocked fuel tank vent
Corroded sticking anti siphon valve on the gas tank
Corrosion at terminals & relays for the electric fuel pump
It takes very little fuel for the engine to start idle or even rev in neutral but under load the problems become more apparent.
Not on Volvos...uses alternator outputI think that some years of Volvos had trouble with the terminals on the relay for the fuel pump; there is also the oil pressure safety switch that cuts electric power to the pump if the engine stalls to prevent the electric pump from flooding the carb.
He has a carb. There is one pump. The ones that had flakes were the dual pump modules used on fuel injected models. If this was a fuel injection module, you couldn't even use a mechanical pump. Starting in the mid to late 90s, GM blocks didn't even come with a place to put a mechanical pump since all automotive use was fuel injected.I think you know the answer to that question Bruce but you must admit you see many posts on boating bulletin boards of problems with V/P electric fuel pumps (paint flakes clogging the pump, terminals on the relays overheating). The guy at cavemanmechanic.com makes a nice living off these problems it seems. Meanwhile a mechanical pump can last 30 years if not longer. Is this progress?
Yes...That's the first thing I would do. After that, checking float level would be my next step.I will do a fuel pressure when I get home. Still on extended vacation at lake without a running boat. Boat that runs in water that is.
I guess you missed where he already used an external tank with a primer bulb.The basic problem with using an electric pump is that it must pull from the tank not push from the tank as in automotive applications. This I believe is due to CG regs regarding electric fuel pumps. So any restriction on the suction side can cause problems. The pump will begin to strain and overheat eventually. And regardless I’d take a good look at the relay and terminals, corrosion/oxidation happens all the time especially here in salt water land.
The point was that’s what leads up to fuel pump problems....fuel system restrictions that may still exist! And if not corrected will cause the same problem in the future...I guess you missed where he already used an external tank with a primer bulb.
He has a 19 year old fuel pump.The point was that’s what leads up to fuel pump problems....fuel system restrictions that may still exist! And if not corrected will cause the same problem in the future...
