2003 150 MercOptiMax Overheating Alarm
weezerr2183
The temp alarm sounds at idle and low RPM. There is a good stream coming out. But if you accelerate quickly there is no alarm and you can ride all day from mid rpms to Wide Open Throttle with not the first alarm. we've replaced the impeller and then checked it yesterday, reassembled, ran out to the lake and it still does it. Any help would be appreciated.
Faztbullet
Re: 2003 150 MercOptiMax Overheating Alarm
Check the strainer on port side of exhaust plate as if restricted it will cause air compressor to run hot and trigger a hot alarm
weezerr2183
port side but where exactly am i going to have to drop the foot again??
weezerr2183
i just found out that its a 2005 not and 03 does that make any difference??
weezerr2183
ok got the screen off but there wasnt much buildup. It didnt look like enough to make the alarm go off. is there anything else that would make the temp alarm go off?
