demarko210
Thread starter- Joined
- Jan 2, 2015
- 655
When i pull the lower unit in the fall I replace the water pump as it broke up while running in on muffs. I have since replaced thermos, water pump, seals in the lower and vacuum and pressure tested it. Now I want to reinstall it. I have attached a image of the water tube inside the mid section. To me this looks like the inside of the old water pump seal and the extension that comes in the water pump kit. I can move the extension in this image up and down. Do need to remove that rubber and pull that plastic down before installing the new pump and extension? I cant remember what came out when i remove the lower in the fall. I think this water tube should be bare when reinstalling.
Thanks!
Thanks!
