2003 df70 suzuki high speed shut down
wrestling coach
I need help with my 2003 DF70 Suzuki. At top speeds the engine will shut down with one short audible warning tone. The engine will then crank but not fire. Following a few cycles cranking another short audible tone and then the engine will fire. Could this be an engine temp problem? I have a strong telltale but I am wondering if the water intakes might have too much algae build up?
Thanks in advance.
clanton
Re: 2003 df70 suzuki high speed shut down
Sounds like loose wiring connection. Check engine light come on? Overheat should only reduce rpms. You ever service the engine?
