weaverunner
- Joined
- Aug 26, 2017
- 13
2003 Johnson 90hp 2-Stroke J90PLSTC
A couple of months ago, the motor started developing a miss and also the tachometer would randomly bounce around regardless of the engine speed. So I tested the stator and it was way out of spec (6.5 ohms) along with some of the epoxy had melted off. I replaced it with an aftermarket CDI electronics one and everything was fine for the next several trips out on the water until last night. While running, the volt meter was only showing battery voltage and was slowly draining on our way back.
I'm almost certain the regulator/rectifier is bad but this morning after I started it up again the volt-meter was reading 13.5+ volts at idle so I don't know if it's just an intermittent issue with R/R or if it's only when the engine is hot. Also, I noticed the same issue with the tachometer randomly bouncing around.
I tested the stator and it shows 1.5 ohms which is within spec but still questioning whether it's contributing to some of my issues. Since replacing it, I noticed much longer cranking times during cold starts (10 sec+) when before I replaced it , it would fire up almost immediately. Also, I've noticed when it first starts cranking (cold starts only), it will almost hang momentarily, like there's too much compression.
Can a bad regulator/rectifier damage a new stator (or vice versa) or do my symptoms only point to the R/R? I'd like to also replace the stator with a new OEM unit, but they're nearly $400 and I am unsure if it's 100% necessary.
