- Joined
- Mar 8, 2009
- 44,651
my smart craft speedo.
This changes everything :facepalm: my bad, I was off in the wrong arena
Smartcraft uses a CAN bus, but .... that gauge will connect to the data link. The kit should come with instructions, but it basically gets daisy chained form the harness of other gauge. You do have to install the sensor to the water hose coming from the transom assembly (you kit number), then connect the sensor to a similar link which would be on the motor (remove weather cap) or it runs you to helm where it connects.
Merc talks about a paddel wheel speed-o which is used on most ski boats, its more accurate. Another way is to use one which links to the system and uses a gps from a chart plotter or such via NEMA
