2005 Mercruiser MPI 5.0L misfiring(?) when in gear, idles fine
searay250
I am not positive on your engine, but the coil may get power in two different ways:
  • One while the starter is engaged (key in the start position)
  • Two when the engine is running (key in the run position)
Need to find a wiring diagram for your engine, please search around on the forum at the Don S MUST HAVE technical info in the electrical section. Also just search this forum and perhaps someone will post it. Troubleshoot it to ensure you have coil voltage in both these key positions. Report on this or ask questions as needed.
Otherwise, no oil or wetness so that is good, and you can see the little mark in the middle of the rotor tang showing it is making contract, also good. Regardless install another set. And check that firing order in the process!
Now once verified coil voltage at both key positions and with a new cap / rotor and proper firing order (heck should replace the wires while at it as well) give it a try and post.
Thank you! This distributor actually has a repair plate already, it just wasn't on for this picture as I had to remove all of that to get the cap off. I think I misspoke... I didn't mean to make it sound like the cap was moving. By "very little play" i mean more like I felt like I could maybe twist it hard and get some of the plastic to bend momentarily, but it's not like it was moving freely or anything :)
But, it sounds like the consensus is to get a new cap anyways. This is the one that was suggested to me earlier in this thread, is it a good one? https://www.amazon.com/Performance-...-CAP1010-DF/dp/B0845M26MW/140-4275339-0125666
I will also check the firing order.
Re: the voltage, here's my thought process, but please tell me if I'm wrong... if the question is whether the coil gets power with the key in both positions... I think the answer is yes, and here's why:
The coil definitely gets voltage while the key is in "start" position. I have verified this several times. So the only question is whether it gets voltage when it's in "run". And i think it does, because *when* my motor kind of accidentally and randomly catches, it keeps running when I put the key back into "run." That's when I get the strongest spark, according to the test light. So I don't actually have any reason to believe that I have weak or no spark even at the plugs when the key is on "run", the only thing I know right now is that I don't have spark at the plugs when the key is on "start" although I do know that I'm getting spark at the coil, at least. And my guess is that, since I don't even have spark at the plugs when it's in "start", my issues are so much more likely to be caused by something with the dizzy or wires than something more obscure like randomly not having spark when the key is on "run" as that not only doesn't explain, but also actively contradicts, my observations.
But, happy to be told that I'm wrong here! It's so easy for me to miss obvious stuff when, as you note @ESGWheel, anxiety is... higher than is should be haha :)
ESGWheel
I have not used that particular cap and rotor but its on my list to do so (I too have a 5.0 MPI but VP, same engine base). I see no issues with it and it was recommend.
Recall you are our ears, eyes and hands. If you are 100% confident have voltage at both key positions, I will avoid the Click and Clack tactic and not treat you as a “hostile witness” :) But to be clear > this is VERY odd what is going on. You should be getting spark at the plug wires, but you do not. This is why we are urging the new cap and rotor and if the wires are more then 5 years old (or unknown) replace those as well. We are a little into the parts cannon space, but the spark at the coil and not at plugs is driving us there.
Are you sure you have spark at the coil? As in snap, snap, snap, rapid fire like a machine gun and not snap….. snap…... snap… Please confirm.
Thanks, and keep it up, this is a head scratcher for sure. But my confidence is not diminished > you have a solid engine as mentioned before based on the compression nos. and you will have great stories to tell back on the water when all said and fixed :cool:
Scott06
I'll try bending the little tang up just to get really good contact and verify that the rotor is spinning. How would I know if it's leaking spark to the ground?
Look for signs of arching in the cap, also if you get spark into the cap and not out of cap to plugs or wires. Just the gap tester you have- should jump consistently 3/8" 9nice blue spark not orange) or so. Testo it off the coil wire , then you should get the same size gap jump off the plug wires. if you have less spark strength at the wires you are loosing it somewhere in cap/rotor/wires.
Stay away from the cheap amazon chit... summit racing has a sierra cap for like $78 , quicksilver is ,about $125
If the dizzy already has the repair ring on it could be as simple as the cap on fitting right.
searay250
First off, I might be a hostile witness.... I would consider it more like an "accidentally ignorant" witness but I think the end result is the same :)
I feel like I have very fast consistent spark off the coil but I will take a video to confirm, so other can see the timing and double check my intuitions.
Thanks. Yeah when I sometimes DO get spark off the coil spark plug (using a tester in the boot), it's not very often and it's definitely orange. I'm pretty sure it's blue off the coil but I will double check that as well.
Thanks!
ESGWheel
1) I feel like I have very fast consistent spark off the coil....
2) Yeah when I sometimes DO get spark off the coil, it's not very often and it's definitely orange.
These sentences appear to be conflicting. Recall you need the snap, snap, snap rapid fire off the coil, less so off the spark plug wire.
  • Is sentence no. 2 for the plug wire and not the coil?
searay250
Ooops! Yes, good catch... I meant:
2) Yeah when I sometimes DO get spark off the plug, it's not very often and it's definitely orange.
I'll edit my original post now to prevent future confusion but I appreciate the catch, that was definitely my typo
ESGWheel
i forgot to mention that these types of dizzy caps usually have the cylinder no. stamped on it for each wire...
searay250
Hi all,
First, I want to thank everyone who has helped with this so far. I completely redid everything "downstream" of the coil and the engine was able to fire up. I am not convinced that I would have been able to get this going without help, and I want to express my gratitude to you all.
I'm pretty sure that the combo of a new cap and rotor was the difference-maker, it's the only thing that I wasn't able to kind of independently test. I would not have ever bought a new set, thinking, "these are new! Nothing can be wrong with them!"
So, thanks!
Unfortunately, there still seems to be an issue, although I'm not sure whether this is related in some way or not. When it fired up, it was idling a little high, so I figured I'd adjust the idle down just a smidge. At some point, I bumped the throttle, and it made a really, really weird almost screeching noise. After some fiddling, I found out that as soon as it throttled up even a little, the noise would start and then slowly die down. I captured the noise on video here, with me just nudging the throttle a tiny bit:
Eventually, after maybe 2 minutes of additional runtime (with some engine shutoffs in between) the noise started to just be there all the time, even at idle:
I shut the engine off as I didn't know what was going on. It kind of seems to be coming from the throttle body/intake area, although I'm not confident enough about the location really pinpoint it for sure.
Has anyone... heard anything like this before? It sounds really, concerning, whatever it is.... I would appreciate any thoughts on what this noise could possibly be, and/or if it's a sign of my engine about to blow up or something!
Thanks again, everyone :)
searay250
Yeah it's so weird. The strangest part is that this noise was NOT there last time the engine ran not even a week ago. I am trying to think through what I actually touched on this motor recently.... spark plugs, plug wires, spark arrestor, distributor cap.... I really think that's it. It's so hard to remember, I guess this is why @ESGWheel (rightfully) notes that the owner of the boat is often an accidentally hostile witness, ha!
This noise seemed at first to be related to RPM because it would show up as soon as the RPMs increased and last even after the throttle was returned to idle but die down along with the RPMs, but then it started to just make the noise all the time, which is alarming. Seems to run and shift fine despite the noise, although I have not actually tested under any kind of load beyond just putting it in gear and making sure the prop turns.
Really stumped on this one. It feels like this could run the whole spectrum from "what a weird but harmless noise" all the way to "yeah your engine is going to explode in 2 more minutes"
Thanks
Fun Times
Hi all,
So, thanks!
From my hearing through a laptop speaker, the sound sounds like you now might be missing your IAC foam Muffler that rests inside your throttle body and it probably blew out with all the backfiring type of air blowing out the T_B/flame arrestor and then sucked in to the engine and out the exhaust system.:cool:
The IAC Muffler is item number 6, https://www.mercruiserparts.com/bam/subassemblydetail/43949003/28193893
At this point you probably should also fully clean the inside of the throttle body with TB cleaner available at auto stores, also get some lint free blue shop towels, engine off, open the throttle and clean both/all sides/edges of the TB butterfly plate, the TB walls around the plate, IAC hole by hand careful not to leave any shop towel parts in the lower part of the TB / intake manifold area. Install a new IAC muffler, clean/wash/lightly blow dry the flame arrestor and see if the engine runs/sounds better/normal.
You installed new spark plugs? What part number did you install?
Bear in mind that you may have a weak Idle Air Control Valve too that either needs cleaning or replaced which will be item number 16 in the parts link above but there are aftermarket equivalents out there at much lower costs that fit the automotive world should you want to go new...Standard part number AC423 also fits a 2001 - 2003 Ford Windstar 3.8 v6.
ESGWheel
Searay
I have been offline for a while so just reading thru your success (congrats!) and next issues. A couple of things if you do not mind.
While glad simple as cap and rotor, which we were all thinking, I am curious about the suspicion that a couple of the plug wires were ‘crossed’ and on the wrong plugs. And perhaps more than my curiosity it helps to have a complete record of how the issued fixed to benefit others.
I agree with Fun Times noise could be the IAC and Nola Mike is spot on that you do not ignore new noises. A new noise, even if you cannot readily find it, if left alone, will eventually find you! So, check it out per above.
More: let’s go back to those grossly carboned up plugs. You are running rich (or were) and we need to figure that part out too. As you are doing the IAC and throttle body cleaning, I suggest doing this: take your spark arrestor (that air filter looking device that sits on top of the throttle body > and while it’s not an air filter, it can get plugged up like one). Place the entire arrestor in a bucket of warm water with a little bit of simple green (or grease cutting soap) mixed in. Let it soak for a good 30 min and then grab it and agitate it while submerged in the bucket (bang it against the bucket walls for example). Getting lots of dirt / back coming from it? Change out water/soap and repeat until you do not. Then rinse the arrestor with only clean water in the bucket, soak and final rinse by squirting water from the inside out (not high pressure, just a gentle stream). Then shake it about and let it air dry. Post if it was really dirty or not really.
One more question: do you have a lot of “black dust” in your engine bay especially around where the belt is? May look like a slight oil leak but when you scrape it up with your finger, it gritty. If you can, take a pic for me of the front of the engine and post. If this stuff exists, its what will come out of your arrestor, and it may also have crapped up your MAP sensor. So let me know.
Recall your goal is to have a safe and dependable boat so you can enjoy. Do not take any short cuts now :) Thanks.
searay250
Thank you! I will check the muffler, although a very preliminary check today with a stethoscope suggests that the noise is coming from somewhere near the rear (possibly).
To answer your question about the plug part number, I put in 8 new NGK BPR6EFS plugs. They are not iridium but it looks like they are recommended for this engine. Please let me know if these are not the right plugs!
Actually, I am not convinced anymore that I had any crossed wires. I had noticed that one seemed to be crossing the loom, but it was just a bad install job... normally, I see people do any crossing that needs to happen in between those two plastic clips, so that at the plug end and the distributor end, everything "looks" straight. There just happened to be one that looked crossed but it was indeed going to the right plug in the end.
I will rinse my arrestor on Wednesday, and see what comes out. I don't have a lot of black dust (I don't see any actually... just normal dirt). Happy to take a photo but what do you mean by a "post"? I'm just not sure what that is.
On wednesday, I'm going to go back and just retrace my steps and basically redo everything. I'm hoping i just didn't tighten something down or whatever and redoing everything will sort out this noise. I will also check the IAC muffler. I know that my muffler is in there now, but it's not in good shape. It's quite black and deformed. I'll buy a new one of those either way as they're cheap and it can't hurt :)
Thanks everyone!
salty3rd
Thanks everyone!
Good luck, hopefully just an easy filter change.
Just to reiterate, I recommend that you carry a spare Cap and Rotor and the appropriate tools at all times as you never know when they will fail. As I said earlier, I had to change mine in the middle of the day just a couple weeks ago.
ESGWheel
Based on the original symptoms after just putting on a new cap and rotor my thoughts were there could be an issue with distributor wiring arrangement. After your pictures of which wires went were, I felt sure there was some ‘crossed wires’ hence the suggestion to validate. Note: by “crossing” I do not mean one spark plug wire physically crossing over another like an “X” but rather that the wire from the distributor goes to the wrong plug. For example, the wire in the No. 5 location in the distributor goes to the No. 7 plug. While the new cap and rotor solved the issue, I also believe that your careful attention to the wiring locations also resulted in them being wired correctly. My curiosity continued to nag at me and so I did an analysis of your pictures showing how this was wired. See picture.
As you can see, I added in the correct plug numbers and notably there are only 2 of the wires plugged into the proper plugs. I find it interesting that it ran as well as it did. On explanation is that your diagrams may have been off and most of the wires were in their correct positions (but not all) after your initial cap replacement.
Wanted to get this in the thread for others that may be experiencing similar issues after a rotor and cap replacement > be sure to check the wires are on correctly! Also, they make wire markers, like this link, that you can put on your wires to help ID them when changing out a cap. Recall these caps are generally marked with which spark plug wire it goes to, so simply match the numbers :cool:
