I am not positive on your engine, but the coil may get power in two different ways:
Need to find a wiring diagram for your engine, please search around on the forum at the Don S MUST HAVE technical info in the electrical section. Also just search this forum and perhaps someone will post it. Troubleshoot it to ensure you have coil voltage in both these key positions. Report on this or ask questions as needed.
- One while the starter is engaged (key in the start position)
- Two when the engine is running (key in the run position)
Otherwise, no oil or wetness so that is good, and you can see the little mark in the middle of the rotor tang showing it is making contract, also good. Regardless install another set. And check that firing order in the process!
Now once verified coil voltage at both key positions and with a new cap / rotor and proper firing order (heck should replace the wires while at it as well) give it a try and post.
Thank you! This distributor actually has a repair plate already, it just wasn't on for this picture as I had to remove all of that to get the cap off. I think I misspoke... I didn't mean to make it sound like the cap was moving. By "very little play" i mean more like I felt like I could maybe twist it hard and get some of the plastic to bend momentarily, but it's not like it was moving freely or anything
But, it sounds like the consensus is to get a new cap anyways. This is the one that was suggested to me earlier in this thread, is it a good one? https://www.amazon.com/Performance-...-CAP1010-DF/dp/B0845M26MW/140-4275339-0125666
I will also check the firing order.
Re: the voltage, here's my thought process, but please tell me if I'm wrong... if the question is whether the coil gets power with the key in both positions... I think the answer is yes, and here's why:
The coil definitely gets voltage while the key is in "start" position. I have verified this several times. So the only question is whether it gets voltage when it's in "run". And i think it does, because *when* my motor kind of accidentally and randomly catches, it keeps running when I put the key back into "run." That's when I get the strongest spark, according to the test light. So I don't actually have any reason to believe that I have weak or no spark even at the plugs when the key is on "run", the only thing I know right now is that I don't have spark at the plugs when the key is on "start" although I do know that I'm getting spark at the coil, at least. And my guess is that, since I don't even have spark at the plugs when it's in "start", my issues are so much more likely to be caused by something with the dizzy or wires than something more obscure like randomly not having spark when the key is on "run" as that not only doesn't explain, but also actively contradicts, my observations.
But, happy to be told that I'm wrong here! It's so easy for me to miss obvious stuff when, as you note @ESGWheel, anxiety is... higher than is should be haha
