2006 merc changing lower oil
smidge112
Changed the gear oil on the lower unit the day on my 2006 15 hp merc. Today when i went to fix the trailer lights i noticed that it had leaked a couple drops of oil. upon closer inspection i noticed that i had tightened down the screw and the seal was not sealing correctly and being pushed out. Backed it out just a bit so the seal wasn't being damaged and i have not noticed a leak. Has anyone else experienced this before?
smidge112
well i only saw the o-rings at my local western marine so i picked some of those up. This is what i used. it originally had one of those plastic ones.
quicktach
Get the correct plastic ones from your Merc dealer. Don't use o-rings. Make sure the hole is cleaned out first and the screw is not burnished underneath. Should be ok then.
Alumarine
Also make sure there isn't an old seal left in there.
I know the o ring from my pump likes to stay behind when I remove it.
smidge112
Yea I bought the o rings without first knowing what I needed. Then when changing the oil I thought it was odd that the two seals were different. But thought I'd try anyway. Guess back to the store I go
