saintv90
Thread starter- Joined
- Aug 9, 2012
- 38
ESSENTIAL DATA REQUIREDWhen posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct. Would love better all around performance...but really need a bit more hole shot for wakeboarding and skiing.
2) Current prop manufacturer, model, aluminum or stainless as a minimum. Mercury, aluminum, dont know the model...but the serial on the side is 832850A45p19 mercury.
3) Current prop diameter and pitch (required). dont know but based on the serial above i assume its a 19 pitch. 3 blade aluminum.
4) Wide open throttle RPM and speed with an average load (very helpful) 56mph at a hair over 3k rpm. Is that low? this was based on the built in speedometer...not gps. Wondering if im maximizing the engine.
5) Engine/drive make, model, year, and HP...mercruiser 5.0 220hp alpha 1 drive. 2006.
6) Boat make model, year, length and weight...2006 tahoe Q7i Alpha one, 20.6 feet...weight is around 3200lbs.
Ive had suggestions of a five blade...four blade...and three blade. Id love to get a faster to plane speed for pulling wakeboarders. id also like to get better control at lower speeds...and better grab in turns. the boat tends to turn high on its side making everyone in the boat feel like we are flipping over in hard turns. Ive heard a better prop will hold better.
Im also considering smart tabs...do those accomplish the same task as those $50 dollar whale Tales?
Thanks for any and all advice! Oh yeah...and id really prefer a stainless steel prop. Thanks!For
