Where is the best place to connect the remote fuel tank on these 5.0 MPI ECT's when winterizing the combustion/fuel system ?
I noticed when following the fuel line starting at the fuel rail right behind the throttle body on the port side, that there is 2 metal lines coming off the fuel rail where the fuel hose connects to one line, and the other is plugged .
I attached a picture. The upper line has the fuel hose connected to it and the lower one is plugged. The lower one also has a foam sleeve on it that I removed for the photo.
Can the plug be removed on the lower line and connect the remote fuel hose to it?
