I have a 1997 225 Johnson Ocean Runner that stalls alot at slow speeds. The motor will crank and run good but when you shut it down it will not idle when it is cranked back up. It is a real hassle when you shut the motor off to back the trailer into the water and the motor will not idle enough to drive the boat onto the trailer when you crank it back up. I have changed the fuel filter/water seperator quite often and run fresh gas and spark plugs. Any help would be appreciated.
