25 evinrude backfires
Xcusme
Re: 25 evinrude backfires
Willow,<br />2 things...Did you install a carb rebuild kit, when you cleaned the carb?? <br /><br />What color were the coils and in what condition were they?? Did you observe any cracks in the coils themselves??
willowcat
I installed a kit in the carb. The coils look good. I'll have to get a closer look for cracks. Would a crack in the coil make it backfire out the exhoust? feul connections are good and the tank is vented well.
moonfish
shoot a squirt of gas in the carb and see if it cranks then. when it kicks in and runs it has spark, but not the rest. I would guess there's not adequate fuel supply. Will it stutter a bit if you prime it? I had the same thing on an older one and there was a big leak around the high and low speed jet retaining nuts. replaced them and it ran like a champ.
Dhadley
Are you sure its backfiring out the exhaust only? Or is it popping back thru the carb at the same time?
G DANE
Hi Willowcat<br /><br />I think Moonfish hit it. <br /><br />If the firing is mostly through exhaust, it sounds like lean-sneezing. I've had a couple of these motors. If you checked spark with a spark gap, and found it fine, try following:'<br /><br />1: Retignten all nuts and screws on intake manifold, and both carb nuts.<br /><br />2: Check if there is a small keyhole shaped silicone gasket around the iddle mixture adjust screw. If there is, and it doesnt fit tight, replace it.<br /><br />3: These low tension ignitions can really tease you. Do check if both sparks will jump a 5/16 gap to ground with strong blue flame.<br /><br />4: Look if fuel and oil squirts out anywhere, if it does you have an airleak.<br /><br />5: Clean the 3 small holes in carb body, inside bore, just above butterfly with a needle or so, remove iddle mixture screw and blow compressed air through. Be aware when assembling again, iddle mixture screw must NOT be turqued to stop. Initial setting is 1 1/2 turn from gently seated in bottum.
willowcat
I found a small hairline crack in the top coil, Could this cause the backfire?
G DANE
Not if your spark will jump the testgap. Try to start it in dark and see if the spark creeps anywhere else. That coil wount last long anyway though.
