Re: 25 hp Mercury carb question
I'm trying to get a 1982, 25 hp Mercury outboard to run for a friend of mine. Never worked on Merc's before, so I bought a SELOC repair manual. The manual says the 25 hp motor has a Type "J" carb. I took the carb off to rebuild it and it doesn't match the carb in the manual. Mine has the fuel pump sandwich mounted to the left side of the carb. Is this the right carb on the engine??? It looks kinda like the Type "G" carb in the manual. Any help is appreciated.
ok its obvious there are no outboard motor mechanics in this forum,i have been trying to simply find out the starting procedure for my 25 merc, with a no choke carb........
look on the side of the mounting flange of your carb, there will be numbers
stamped there mine is stamped 7484,,,that crosses to a tillotson BC1B carb
good luck getting anything else,,,,my carb is obsolete,the .03 cent gasket on the top of the carb ,, they want $15.00 for it, if you want a rebuild kit
thats neet,,,,,,,absolutely no mention what is in the kit. but for 33.00 and shipping of 10.00 for a 2 ounce kit, that they could send in a first class
envelope,for normal postage,,,untill you get it you still dont have a clue what you have ordered.
you talk about a huge ripoff,,,,,,,,,,,good luck
