Re: 250 Inline 6 Engine Year
I just purchased a used block in good shape, which I will most likely rebuild. I am trying to find out what year it is. There are the following numbers on the side of the block near the starter - "K2310 37712 GM91" I tried searching info on the motor, but found the serial numbers are longer. Any info on these numbers? Should I look elsewhere for the serial number?
The 37712 number sounds close...
http://www.castingnumbers.info/site/search/37712
If you hunt around, you can find info on how to decode date codes, and locations of different numbers. I believe your style 6 had stuff stamped on a pad behind the distributor. Not sure if this is what you are looking at now. If you believe the head is original to the block, pull the valve cover off and look at the casting numbers there. There should be a casting number for the head, and if your lucky a 3-4 digit date code with a letter possibly representing a month.
The K2310 you got from the block sounds an awful lot like a date code...
K standing for November, 23 standing for the day of the month, but 10 makes no sense. Are we sure its a 1 and not a 7, and the 0 could be an 8 or 6?
