260 Mercruiser - Thermostat spacer? Where do I get one?
Alwhite00
Pulled my thermostat housing off and there are 2 t-stats - the upper one has some sort of spacer to hold it in position - Like a tin looking ring. Well, It was coroded pretty good and got bent up while removing the t-stat.
Where can I get a replacement and what is it called? Also, The t-stats look different than the standard automotive type, Are they different?
Also - Are there supposed to be 2 thermostats - I looked in the book and it looks like there is only one - It ran fine and the temps were fine, Just checking to see if this is correct. There was one directly in the top if the intake manifold and then one in the housing with the spacer.
Freshwater cooled engine BTW. Boat is a Sea Ray Seville 210MC - 260 Mercrouser (350) and a Alpha 1 OD.
Thanks
LK
Re: 260 Mercruiser - Thermostat spacer? Where do I get one?
Ayuh,... There should be only 1 T-stat, 'n Mercruiser sells the parts for the housing...
Alwhite00
I thought that seemed very odd with two t-stats - I assume that the one directly in the intake is not supposed to be there?
LK
Didn't see the info on there, Maybe I am looking in the wrong spot.
LK
Ayuh,.... Did you download the manual,..??
It's the factory full engine service manual....
Click the Big blue Download Now button....
Alwhite00
Got it, Thanks - I was thinking I could view it on line.
LK
