havoc_squad
Thread starter- Joined
- Mar 5, 2011
- 741
Brief summary:
1993 Mercruiser GM 3.0L engine.
Boat ran great last year, winterized and I believe the fuel was stabilized. No carb issues whatsoever.
New spark plugs were installed before de-winterization.
De-winterization attempted, fuel pump failed on me. No start, primed intake with gas, ran fine while it had gas to ingest.
Replaced fuel pump, fuel filters changed, runs however idles badly on muffs. The longer it runs at idle, the more it seems to lose strength and basically stumbles nearly to a stop.
As soon as you let the throttle make up the slight difference, the boat runs fine at 1100 to 1700 rpms. I think it would run fine on the water in higher RPM's. However I don't think it would even let me get in gear with how rough that idle is.
I am going to run a half a can of Seafoam through the fuel if possible.
Any tips on gauging if this is clogged idle port(s) or something else?
I'm tempted to want to see if the idle mixture adjustment needs to be changed, or the idle speed adjustment. However, I don't want to incidentally create a high lean mixture issue or do something really stupid.
I'm just asking so I can make sure before I go and pay for a $450 carb rebuild on this thing. It's bad enough that I boneheadedly spilled a 1/4 of a gallon of gas over my boat carpet only 9 months old at the back while trying to run a test tank. It delaminated up and I've now got to pull up the damaged area to splice in a new piece, man am I glad I kept my leftover carpet.
Meh, its always something that needs fixing, or that needs breaking, like last weekend.
