Erie88renken
- Joined
- May 15, 2012
- 22
1988 renken classic
3.7 mercruiser with alpha one model 165, 2 barrel carb.
Im trying to get this boat in the water. I have been using this forum nonstop. Mostly I find the answers to my questions by searching the forum. Thank you.
I find conflicting info on my next question which is why im posting it now.
I took the valve cover off to insure all my valves were working properly (not stuck).
I noticed a few of my rocker arms seemed loose. They jiggled around a little. most did not. I turned the engine over by hand and they stayed loose no matter the stroke. The bolts are to correct torque. I took the rocker arms off and pulled the push rods. They all looked fine. ( kept them in right order/position). I rolled each one on glass to verify they are strait and a few are not. Decided to replace them all because they are a cheap part. This is where I get lost.
I can punch in 470 merc pushrods and get a set of the interweb. They are all the same size.
?OVERALL LENGTH: 8.647"
?TUBING SIZE: 5/16" X .060" (stock)
?ENDS: 5/16" Ball
This is the most common size I find.
But then I find sets that are multiple colors and multiple lengths from merc....why.
I also find mixed info on this forum. I have seen people say you have to measure each one and I have seen people say they were fine with the replacements from the web. Also, I hear people talk about a valve clearance tool? What is it? I assume its to measure the gap between the valve and rocker arm, but I have always used a feeler gauge for that.
If you have the time, please explain.
A little more info....bought boat 2 years ago. Had sat for 2 years. I started to mess with it, ended up rewiring dash and most of boat. Finished that in November. January of that year I was shot by accident in the knee and was unable to work on it for next year.
Couple weeks ago I started working on it. Replaced starter, battery, cables, points, condenser, coil, carb rebuilt.
Now I try to start and it just cranks. After I had carb off and back on it at least choked a few times. I don't understand why it wont start. Would bent pushrods keep it from starting? I just got back to do a compression test. I think I did one before I got it and they were all in low 140. Is it safe to keep cranking on it with bent rods? Only want to do it to test compressuion, but I am thinking bent rods would skew results. Sorry so much info and questions.
Boat....Best Of All Times
?ENDS: 5/16" Ball
