30 Hp Johnson ID
Bogus
Hi all , after some help if i may,have purchased what i believe to be a 1998 30 Hp Johnson outboard,firstly i would like to confirm this,the numbers on the transom mount tag are :W1PXMD082210,the word Johnson is no where to be found but OMC is also on the Tag,i really would like to confirm what model it is so i can order a cover and also and air filter which appears to be missing please see link:
http://forums.iboats.com/attachment.php?attachmentid=24567&d=1237322975
appreciate any help sorting this Cheers Bogus ..
Vanover
Re: 30 Hp Johnson ID
there should be a small silver plug on the powerhead of the motor. It should have a series of numbers on it. Do they match the transom plate. If so okay, if not what are they? I was umable to id this motor using the standard chart i have. Sorry if you come up with any other numbers let me know.
Haffiman
For your comfort, nothing is missing.
It never was anything in front of that carb.
Due to the black power head paint, I would so far guess it to be a later 80's engine.
However hopefully the 'dime' on the block will tell.
Bogus
Really??? no intake air filter???seems odd especially with the threaded bolt holes...thanks for that info..
ok so the number on the silver dime is as follows:64378450
where would i be best to start a search for a engine cover???thanks for your help to date ...cheers Bogus..
Haffiman
It should be some letters??
In worst case, 'RPH' that stands for replacement power head.
Does the engine have a UFI (Under Flywheel) power pack, or a separate one at port side at the back?
(If the primary leads to coils disappears under the flywheel, an UFI.)
