Ricky B
Thread starter- Joined
- Aug 4, 2009
- 18
1). Went thru 8 pages and eleven years of Search but couldn't find any open & relative threads to ask this question.
2). Starter motor works perfect, bench tests well. All ground and battery connections cleaned and properly re-installed.
3). Battery in great shape and holding charge.
4). Great spark to both plugs.
5). Compression seems excellent (Can barely turn her over with a rope)
5). With the starter motor installed and hitting Start, the Bendix gear won't drop back down on it's own and the flywheel will only turn a 1/4 turn or so before things bog down and nothing moves----just the noise of the starter motor tying to turn the flywheel from a dead stop. Have to turn/jiggle the flywheel after turning key off to get her to fall. HOWEVER, with the plugs REMOVED everything works as it should and the gear drops as soon as I turn the key to OFF.
6). I've lightly PB Blasted the shaft then put a few drops of light oil on it, checked for rough spots and/or burrs (on what I could see without removing the gear completely, just the shaft nut), stretched out the spring a 1/4" (to get a bit more downward pressure, took a brass wire wheel to all of the flywheel and gear teeth to remove crud and have checked the clearance/engagement/meshing of everything to see if there's any binding going on-------there's not, as I can rotate the Bendix gear a degree or two while it's still 'stuck' on the flywheel teeth. Nothing is sticking----but the gear refuses to drop on it's own accord.
7). To summarize, spark plus installed, Bendix stays up. Plugs removed, flywheel spins like a demon.
8). I'm missing something really stupid here, isn't I?......
