pabloescobedo96
- Joined
- Feb 7, 2009
- 107
Re: 35 johnson pops out of gear after water pump replacement
The gears and clutch dog were worn fairly bad. The symtoms of that were popping out and then back in gear. Now it pops out stays out and shift lever moves into nuetral.
I too think it may be the shift rod issues but I would like to know what tests can be done to find out.
Like I stated in my latest post I think I may have found the problem. with the shift lever assembly at the motor and inside the center section. did you read it? and do you think that could be the issue?
Well it can mean 2 things, I'm thinking being rude and no I don't know everything. The reason I asked if they were new is some on here find it more cash friendly to buy a used forward gear and clutch dog than new. Putting in used parts can lead to the same symptoms. I wouldn't have replaced the parts, like you said in your first post, you replaced the impeller and now it's doing it. Why would the motor start popping out of gear after an impeller replacement, you don't touch the gears when replacing an impeller, the only thing you touch is the shift rod. If the shift rod isn't lined up properly when it's reassebled and the lengths are not right you will start popping out of gear. Now the question and answer as you so love my methods, was the clutch dog and gear shot or were they perfectly fine?
