Re: 350 Engine advice
MBAKER, Good info, point taken, you should always check!
To stroker, IMO the 252 cam is not quite enough, I recommend this cam:
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=2&sb=1
This is a mild tried, & true, proven orig. equip. hi-perf. Chevy design updated by Comp cams. It is a plug, & play bolt in, that uses all the orig. valvetrain parts with a safe amount of extra lift, and a safe amount of extra duration to make it worthwhile without going crazy, but quite a bit better then the stock "plain vanilla"
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=1&sb=1common cam (used in almost all stock chevy small blocks
) not to say this is a bad cam, it's smooth, and will provide 300hp in a 10:00X1 compression (double hump head), 4bbl, dual exhaust 327! I know I had one! But, the 151 cam above, will give you a 25hp boost, with no other changes in that same 327!
So, you can guess what it'll do for your 355!
I had this 151 cam as well, in a different engine, you might find a slightly lopey idle, but it will pull strong from off idle to about 6k rpm, you'll probably have to prop down to 4600-4800rpm with it.
Heads I can't help you with, but I know the Vortecs are the best stock heads, but may require extra matching parts, or machine work to fit.
