350 merc efi idle problem
dusty456
04 350 mag mpi will not idle. voltage is okay. will start with throtle open and runs fine.
Re: 350 merc efi idle problem
Hi Dusty,... Welcome Aboard,.. again,..;)
Being an electronic motor, you'll have some issues I can't help you with....
But,...
1st place to start is to insure you're getting a good clean fuel supply,...
In other words,... Check the Filters....
Some of the other guys will be along, with some pointers on testing the Electrical side of things...
Don S
First, head up to the Adults Only sticky at the top of this forum, go to the service manual links and download manual #36.
Familize yourself with the tools and expuipment necessary to check out an MPI engine.
Then head to section 2A.
Starting following the charts from page 2A-8 through 2A-11. If you still have problems after checking those items, move on to chart A-12 on page 2A-33.
dusty456
Thanks for the advice. I will check out the manuals section. Sorry about the newby hi-jack earlier. I always learn the hard way........
