3L core plug
machz1000
Is the core plug at the rear of the engine (behind flywheel) the same size as the ones in the side of the block thanks
No, and if you lost a core plug, you most likely have a cracked block as well.
How did you winterize?
Not my boat fixing it for someone else wasn't winterized propeply.
you know that the block is most likely cracked just under the manifold. it may also be cracked just above the pan rail on the inside.
