Engine: 2005 Mercuiser Turn Key Start, Alpha One Gen 2 Drive Serial: 0W356097
Some of you may recall my previous thread about my tub running on... Anyway; I've recently started using the boat for skiing and its running on for about 5 or so seconds each time I turn it off....
Plugs are correct
Timing is fine
Running regular unleaded fuel (91RON here in Australia)
My Idle speed is set at about 700rpm, BUT if I throttle up and come back to idle it sits a little bit higher (say 750rpm)? Does this mean that the throttle plate isnt closing properly?
What can I do to fix this?
Do i need to lower the idle and turn the mixture screw CCW?
Thanks in advance,
Chris
Plugs are correct
Timing is fine
Thanks in advance,
Chris
