4.3 GL-D Electrical Issues
PutMeOnTheWater
Great news. And yes, a loose fuel filter could allow air to be sucked in and cause issues. So, no need for new thread for “no start” condition.
How is are the wiring issues that started this thread working out? All set?
I just posted a reply to @alldodge about the ran/black wire. I think it goes to the oil pressure switch but I can’t find said switch.
alldodge
Either Teed with oil pressure sensor or look below the Dizzy and it might be there on the rear deck. If there is just a plug filling hole then switch was left out
kd4pbs
Oil pressure switch is right above the oil filter - or if you have a remote oil filter, above where the adaptor attaches to the block.
alldodge
Yes but the oil pressure gauge sensor is normally there. Does the oil pressure gauge work?
If it does than sensor is elsewhere
PutMeOnTheWater
Yes it works but it’s a little jumpy. I was thinking of starting a new thread to figure that out. This is the sensor next to the distributor, right?
PutMeOnTheWater
This is the fluctuating I was referring to. I can hear a very slight change in the sound of the motor when it’s spiking but I’m not sure if that sound comes through on the video.
  • IMG_5870.mov
alldodge
Correct
It works the same there as down by the filter
I don't see an issue, might just be a loose connection
kd4pbs
Looks like either this never had the oil pressure switch or someone removed it and let the switch connector dangle. Usually there is a sender which feeds the gauge as you identified up by the distributor and a switch that turns on the warning horn down by the oil filter.
