4.3 h.o vortex good or bad?
HopinImFloatin
Re: 4.3 h.o vortex good or bad?
please correct me if i am wrong, and i may very well be, but dont the vortec engines use 8 bolt intakes? afaik all automotive ones were unless some of the real early ones were 12. Unless marine applications are different. Just curious, i may need one in the future.
JasonGS
I have never serviced and i/o how do you do it?
JasonGS
How can i find out what motor I have? Because the number i get off the block matches up with the vortex motor...
HT32BSX115
You didn't post pictures of the drive but the first picture does show you have the older dog clutch Cobra and not the newer Volvo style SX. That's too bad.
Yeah. It's also not a 94 model either. The 94's were the cone-clutch models..........So the presence of the ESA and shift actuator indicates it's a Dog-clutch model according to the BRP parts site, it would be a PRE-94 model. (93 or earlier if someone has done some swapping in previous years)
You need to get an OEM OMC service manual (on ebay, craigslist, etc)
Do a little reading. A dog-clutch Cobra MUST be serviced (with oil) using the correct re-fill procedure or you will destroy the drive.
bruceb58
Vortex or Vortec? GM called all of the 4.3L Vortex. True Vortec heads weren't put on GM engines until 1995.
JasonGS
How can i tell what kind of motor i have? I found the block casting number and it came up with the vortec motor.
bruceb58
Please show us a link how you determined this.
Your intake manifold have 8 or 12 bolts holding it down? 12 = non-vortec. Actually, I can tell from your pictures that you don't have Vortec heads.
http://www.chevymania.com/tech/vortec.htm
Look on the transom assembly for the model number. Should look like what Rick posted earlier.
JasonGS
How much HP am i looking at?
JasonGS
My model number looks like 434aprjun but that isn't listed so I am assuming that its 434aprjvn... Whats the specs on that motor I cant seem to find it on google?
Vortec heads came out in 1996, the engine is in a 1994 boat. NOT a vortec engine in this case.
