4.3 L Starter wires
Cksteiger
I'm making great progress on a rebuild of my 1986 Merc. 4.3L V-6 that someone else took apart for me. Had to replace the starter & on the new starter there are 3 poles for the wires. The main is for the 3 hot leads & then I have only one wire left. I recall that on the old starter that wire was on the block side of the starter (looking down from the top) but I don't recall if it had that extra post. I can't tell from the picture in my manual which lead that wire goes on. Can anyone confirm which post to put that last wire onto?
J JACKSON
Re: 4.3 L Starter wires
if you are talking about the wire with the small eyelet.If your boat only has one it goes on the S terminal on the solenoid. S stands for start
Don S
IS this an OMC, Mercruiser, or Volvo 4.3
The wiring is different on each one. And what color is the wire you can't figure out?
Cksteiger
Sorry I forgot to post that the 4.3 is a Merc.
Cksteiger
I know that the wire goes on the starter - just uncertain if the left or right post.
Don S
Terminal B Should be a Yellow w/red stripe wire.
Cksteiger
Don S. Any chance of finding this sort of diagram for the re-assembly of the power steering & alternator. As I mentioned above, someone else took this all apart for me. My Mercruiser manual has lots of good info - but is pretty minimal on photos/diagrams like this one.
Don S
Sure, up at the top of this forum is a sticky titled ADULTS ONLY. In it is a link to the OEM service manuals you can download to your computer. Free.
Cksteiger
Thanks Don - unfortunately I have previously downloaded that manual - for my model it is #7 and the pictures are not very clear or detailed. I'll keep looking.
