4.3 Mercruiser - Stalled - Will not start
thumpar
The gauges being dead would not have to do with the shift interrupt. It sounds like it may be some kind of ground or connection issue.
Mulligan18
Friends,
I am sure all are pretty tired of my on going problem here but I think I have finally stumbled on the problem. It is a short in the small black wire immediately at the base of the interrupter switch. I did install a new slave solenoid but I found that the gauges remained dead and no crank when turning the key to ignition. Just by chance, I happened to notice that the small fuse/breaker reset button under the key was poking out. I reset this and it started right up. I wend back and touched the black wire and the motor stalled out. Within a few seconds the fuse button popped out again. I restarted the engine and very gently manipulated the black wire and the engine wanted to stall and the slightest touch. It finally stalled and I looked back at the key and saw the fuse pop again. So, it seems pretty certain that I need to install the new style shift interrupter. I will look for past post on how to accomplish this. I would very much welcome a link to a good post or any further advice.
Thank you,
Mulligan18
