4.3 operating temp
Aquaman
I've got a 1988 4.3/Alpha 1 RWC combo. Cruising temp runs 140-145 F. Never goes above 150 F even at extended (5-10 min) idle. Is this normal operating range?
Aquaman
Re: 4.3 operating temp
Thanks for the reply. The auto tech in me thought it was a tad cool.
bjcsc
It is a tad cool with regards to efficiency. That's the trade-off to slow the corrosion down and keep the salt in solution...
Aquaman
My thoughts exactally. I was wondering if maybe I had a stuck or missing t-sat and possibly using more fuel than necessary.
bjcsc said:
slow the corrosion down.........salt in solution...
Does it also slow corrosion in a fresh water application?
bjcsc
Yes...corrosion in general is accelerated by higher temps.
bruceb58
Honorary Supreme Mariner
It's not the corrosion as much as the temperature that salt starts coming out of solution.
ziggy
yer right where i'd want my engine performin at..... yer richous......almost forget the auto mech in ya. this is marine application. the only auto mech that applys in marine is the most basic of engine functions....... yer t-stat starts to open at 140 and is full open at 160........if ya want to test it stick it in a pan of hot water with a thermometer and see what it does.....yer cool man......no pun intended.......:)
Aquaman
Thanks for all the replies....sure beats another "overheating" post huh? 8)
