4.3L long block...
kewlkatdady
So I'm ordering a long block from Rapido Marine.
They are verifying which motor I have and at the end of the conversation, I'm getting a "090" motor...
I think this is referring to the casting number.
Is this the casting number on the block?
The motor being replaced is listed in my sig for reference.
TIA
Re: 4.3L long block...
Ayuh,... I'm guessin' the #s cast into the aft, portside, upper corner of the block, End with 090...
Right behind the head, under the wiring harness....
Alpheus
Right from Rapidos website.
090????...96-99???.4.3L?Roller Cam Engine With
Balance Shaft. Has 6 Bolt
Timing Cover And 10 Bolt Oil
Pan Rail. Head Casting Number
772 Last Three Digits.
http://www.rapidomarine.com/default.aspx?p=/block_casting_id_.aspx
If your'e on the phone with the guy and hes throwing out numbers or something you dont understand, ASK. Hes a really cool guy and will tell you anything you need to know about the engines he sells...
kewlkatdady
Yeah I saw all the info on the site. I talked to him. Its just my way of checking what he's saying to make sure this goes as seemless as possible.
And for that matter proving it to myself...
Maybe I'm over thinking it...but I only want to put one motor in the boat if possible...
I didn't get a chance to go check the casting # in the motor in the boat. I'll try and get by there tomorrow.
and thanks for the info...
