4 barrel bogs down with hard accelerations (Mr. Newby again)
njmedic3306
21 foot Chris Craft
5.7 Goodwrench
Holley (shiny 4 barrel)
So I if I accelerate hard (point where secondaries should open) it bogs down. If I accelerage slowly it is fine until around 4200 rpm where again it bogs. How can I tell if its a problem with fuel delievery or my secondaries not functioning properly?
zbnutcase
Re: 4 barrel bogs down with hard accelerations (Mr. Newby again)
Check fuel pressure while running it. Vacuum secondarys or double pumper?
franktrav
bog on hard acceleration ......check accelerator pump for proper function-should shoot a good stream of raw fuel when throttle is abrubtly opened.
4200 bog.... ensure you have a clean fuel filter,and adequate fuel pressure at carb,if that checks out-could need float/needle&seat/or jetting adjustment...or just a good carb cleaning
Aloysius
What kind of shiny new holley????
71satellite
Hi there,
I recently purchased a boat (with a Rochester Quadra-jet, but that isn't important) that had the same problem the first time I took it out on the water.
I've worked on carbs for a number of years (in muscle cars), but due to other obligations I don't have time to rebuild it at the moment.
My plan was to liberally spray the carb with carb cleaner, and dump a lot of fuel system cleaner into the gas tank (tank was almost empty when I bought it). If that didn't work, I was going to fill a 1 gallon jerry can with gas and fuel system cleaner, and temporarily route the fuel intake hose from the fuel pump into the jerry can, then let the engine run in the driveway and burn through the gas.
Well - after the spraying with carb cleaner (especially heavily at the accelerator pump nozzles) and putting lots of fuel system cleaner in the gas tank (plus about 5 gallons on fresh fuel), the boat ran MUCH better today. Noticeable improvement from the start, and further improvement in the first ten minutes of running.
Now, this was a really cheap and lazy way to try to fix the problem, but it seems to have worked quite well. I suspect that in order to get flawless performance eventually I'll have to tear down and rebuild the carb. But for now at least it is running better.
Hope that helps,
Chris
njmedic3306
Ooops...after looking at it again its not a Holley but a shiney Edelbrock. I do like your idea of new gas. I have had outboards that just don't run right on old gas and since this is a new boat to me I don't know how long that gas has really been in there.
