FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Yes! I may have seen that, but didn't recognize it. Thanks. I'll dig around, on the starboard side, by the terminal block. I bet it's hiding under some "spaghetti".
Keep hanging around and someone will have a problem that you have already solved, and you will be able to help them the way others helped you.
Every one here is a great source of information and has a lot to contribute.
retiredfornow, are you working on the exact same engine as Snowfish? If so click on the link in post #2. Otherwise if you would start a new post with your model number I am sure someone will help you.
Not sure what the wire color is. Didn't look. But if it's the same motor the fuse is in the front of the powerhead just port of the plugs. It looks like a connector, but isn't. Sealed up pretty good, but really easy to get to. Just pull the cover, look down to the left (port side) by the plugs and disconnect the first connector that you find. Bet there's a 20amp fuse in there.
