- Joined
- Mar 8, 2009
- 44,278
Your thread at Marine Engines list you swapped the ECM's and harnesses and there was no change. Swapped complete intake with all sensors and no change
Everything on the new motor works fine on the old motor, and everything on the old motor has no effect on the block motor. Prior to new long block, that motor was doing same thing as this one.
You say long block, so the new motor comes with new heads?
Are you using new intake gaskets for each swap or reusing old one?
