470 merc water pump seals question
fmalott
it's a known fact that the seals wear a groove on the camshaft and you have to put a sleeve on the cam to compensate for these grooves when they are deep enough. question is do you have to put a different size seal on with the sleeve
achris
More fish than mountain goat
Re: 470 merc water pump seals question
....do you have to put a different size seal on with the sleeve?
No. The speedi-sleeve is very thin and you use the same seals as normal....
Chris.......
fmalott
great because i bought the seals forgetting i need to put a speedy sleeve on. where do you buy these sleeves
achris
In Australia I know where to get them. :D Sorry, can't help you in Canada. Try looking on-line.
Chris..........
Edit:
Found this on-line, in your state too.... :D
SPECIALTY SALES & MARKETING
Ken Coulter
VP, Automotive
Millcreek Drive #5
Mississauga, Ont L5N5V3
PH: 905-816-0011
FX: 905-816-0411
Originally made by Chicago-Rawhide. Which has been merged with SKF, so they will be under the SKF umbrella............
fmalott
how bad does it have to be to use a sleeve? When i was feeling were the grooves are you can barely feel them but just enough to know they are there
dollarten
There is a place called Motion Industries They should have speedi sleeves for you There is one In Ontario Just give them the outside dimension of the seal area and they should fix you up
dollarten
You may be OK as is but , if you put the speedi sleeve on , you know the problem will not come back to haunt you . It would be like putting speedi sleeves on a boat trailer axle . It's just better insurance
fmalott
yes there is a motion ind. near where i live
achris
If you can feel the groove, sleeve it....
stonyloam
Carefully measure the diameter of the camshaft and take that information with you. A digital caliper should work very well for taking the measurement, or I think a 1 inch micrometer is large enough to take the measurement. Quick tip when you put the seals in make sure both face away (garter spring side faces out) from the block, and while you are at it you should replace the crank oil seal (spring side toward the block).
fmalott
yes i'm replacing everything i'm totaly rebuilding, new rings, bearings, all seals and gaskets new fuel pump, water temp sensor, oil pres sensor, the whole works and with the outdrive i just went ahead and bought a brand new one, to repair the old one would of costed me just about as much as a new one
vincechig1975
Is this a temporary fix to a permanent problem?
stonyloam
It is a semi-permanent fix for a permanent problem;): should be good for another 10-15 years:rolleyes:.
fmalott
sure the 470's have there problems but as i read many of times before preventative maintence goes a long way
