470 shift interrupter
aarons 470
I’m a bit confused what you mean by spacer, do you have a pic please? Are you talking about putting a verticle spacer On that bigger post after I ream the end?
And my current cable end does have some spring back, If that means anything.
What do you think about the first pin post where My plastic thing would just sit on top of the end of arm with pin through it?
aarons 470
Thank you sir, any thoughts on this one? Just lay on top and pin though?
aarons 470
[No message]
aarons 470
Here it is that way.
aarons 470
Now just to make a real plate.that wasn’t to bad, very relieved. Trim senders next. Find #1 cyl. Then drop distributer and run plug wires. install new trim pump assembly. I’ll prob have to modify.
and tune up outdrive.
aarons 470
Forgot to post finished setup.
aarons 470
Thanks, It was working good until I decided to replace the Bellows and a lower shift cable. cable is next on list followed by trim pump install.
To do list kept getting longer,
now it’s gradually decreasing.😎
