470 to 4.3 v6 wiring
philbullet
Iam sure this has been asked before, swaping out a 1982 470 to a 1996 4.3 v6 ,with ele. fuel pump,carb., complete swap, motor to prop.
Will the main wire harness from dash work,main plug on motor?
Watermann
You should just pull the harness from your donor boat and use it. I saw in your other post you have a running donor.
philbullet
Yep i could do that to,but it would be more head ack.
Blueghost924
I have a 1982 470, and it uses the round 9 pin connector at the engine, and the standard 8 pin rectangular connector at the cabin wiring harness at the other end.
achris
More fish than mountain goat
All the diagrams I've looked at indicate you should have a 10 pin connector, so the answer to the question should be 'yes'....
