Ranger Dave
- Joined
- Apr 4, 2003
- 28
Ihave a 1979 Johnson 4hp that loses power at high rpms. It bogs down and acts like it isn't getting enough fuel. I rebuilt the carb and it still does the same. I should add that I use this 4hp on my canoe so it runs at higher rpms most of the time. I notice I can only get 10 kph (6 mph) out of the canoe now. It used to have no troubles getting 12.5 kph out of the mighty 4hp (measured by GPS).<br /><br />I checked the compression and both cylinders show 90 psi. I squirted in one pump of oil from my oil can (10W30) and the compression jumped up to 145 psi. I think my rings are shot and this is why the engine runs poor at high speed and sounds sick. I ran the oil mixture at 25:1 and the engine ran better.<br /><br />Any suggestions, comments, thoughts on my problem. Also any suggestions and comments on rebuilding the powerhead? I have a repair manual for it and it mentions the crankshaft bearing alignment is critical. I build gas turbine jet engines for a living so it isn't "over my head" to work on engines.<br /><br />
