5.7 Cast Iron Intake Manifold - Salt (‘raw’) Water Cooled
Lou C
Same I also do a compression test & oil analysis. If there’s sodium in the oil from salt water cooling you’ll know it that way for sure.
Lou C
Forgot to add that I use an inspection camera to check for internal leaks in the manifold to elbow gasket. This saves a lot of time if you have no sign of leaks from the outside…
