OMC never worried about that either. No, really, they did have lift rings. The lift rings were fastened to the heads. But they are long gone since the alum. manifold came along!
Why are you afraid of lifting from the carb plate?
Without knowing exactly what you intend to do with the engine once you get it out, I can only offer up the following. Remove the exhaust manifolds (lightens the load considerably) and use the now available exhaust bolt holes to attach a chain on either side (opposite ends) Now just buy/rent a spreader bar, attach to the two chains and voila!
Yes you do. I bought this boat to restore. I have merc parts to replace the OMC with. I have another parts boat.I'd remove the exhaust manifolds and use 2 grade 8 bolts in the heads to attach your chain. I believe they are 3/8-16 threads.
Not to change the subject, but do I see one center rise manifold and one log manifold on that engine??
yep, and really high rise riser on the one side too
kinda makes me wonder about the quality of the rest of the engine package....
to the op - remove what you have to and attach a chain to the heads using, as posted earlier, 3/8" X 16 bolts
this will provide ample "pulling" force to lift the engine (including exhaust manifolds)
remember - saftey first!!! double, triple check your set-up before lifting the engine, and go slowly - use a quality flashlite to inspect while pulling (look underneath while the enigne assy is up, on those "cob-jobs" hidden ground wires, etc... can be a pain)
And that would be a mistake. Taking them off is no big deal and will make pulling the engine much easier.
I'm going to reinstall the engine in a few months after I glass in the new transom, mounts....etc. Why would it be a mistake to pull engine with manifold on?
Ayuh,.... Because it's nearly an extra couple hundred pounds, 'n ya Need to use those bolt holes to attach yer chains....
They've Got to come off anyways,...
Yer life will be Easier, if ya pull 'em Now, insteada Later...
Originally Posted by 79943 i agree the bolts in tensile such as with a lift plate are far stronger than a chain link in shear. the bolts and plate i would not worry about. i am not as comfortable with the threads in the cast aluminum or for that matter the aluminum period. i suppose it would be fine with a big block even with cast iron heads. i will be lifting mine pretty soon (i hope) and i will do some research to find out the tensile strengh of the aluminum which i assume is probably T6000 series(?) not sure about that. |
Originally Posted by Silver69Camaro lifting 1000lbs from four studs is a drop in the bucket. |
Thanks, MOM!
It's a little scary but life is boring w/o a little excitement!
