5.7 mercruiser add 2nd battery/switch
bruceb58
Honorary Supreme Mariner
Re: 5.7 mercruiser add 2nd battery/switch
An ACR does not charge one battery and then switch over to the other battery. It just senses that one of the batteries has a voltage over 13.6V or so and then combines the 2 together.
http://assets.bluesea.com/files/resources/instructions/980014350.pdf
For the Blue Seas combiners it combines when it sees one battery at 13.6V for 30 seconds or 13.0V for 2 minutes.
In a 1/2/both switch, The battery selector selects either battery 1, battery 2 or both. The switch connects them together in the both position. When the switch is in the 2 position, it is not combining the 2 batteries and it never isolates the ACR in any of the positions.
http://www.bluesea.com/products/9002e/e-Series_Selector_Battery_Switch_with_AFD
With a switch like this, you have everything tied to the common terminal of the switch.
JustJason
I misspoke a bit. I should have said switching to "All/both". I'l go back and fix that.
firstinfireman
Thanks a million guys. I got it goin my way now... If it will just warm up and dry out!
