Re: 5.7 with 280 vp gear oil?
Don, i put 2 1/2 quarts of oil in the drive, but it didn't show up on the dipstick.
You don't fill that drive through the dipstick hole or by pulling the top cap. Do you guys just make this stuff up as you go.
You fill through the fill fitting on the back of the upper gear box, then wait for the oil to fill the vertical shaft.
You also need a new top cover gasket or you will have a leak.
Had to look this up in my VP manual, was worried I'd been doin it wrong for all those years?
Oil filling
1. Install the oil drain plug with a new O-ring.
2. Tilt the sterndrive to the full up position. Remove
the fill plug and fill with approx. 2.2 liters of gear oil.
See Technical Data. Install the fill plug with a new
gasket.
Tighten the fill plug to 35 Nm (26 lb.ft.).
Lower the sterndrive and check the oil level with the
dipstick.
If necessary, Top off the sterdrive with oil
through the dip stick hole.
3. Install the shift mechanism cover.
He already had 2,5 quarts in there, all though they where wrongly added I assumed the oil was in the drive, filling up thru the dipstick hole is what I normally do if it's missing a little bit of oil.
By the way the fill plug is behind the shift cover!
