bill lewinski
Thread starter- Joined
- Mar 31, 2010
- 40
Little history first. I got the motor because the previous owner couldnt figure out how to fix his lack of power problem. Long story short the bulb on the fuel hose was bad and after checking the spark strength with an adjustable ingnition spark tester I found out there was no spark to the bottom cylinder. Problem was fixed by replacing the plug wire. The other owner showed me the receipts where he had paid to have the carbs rebuilt by a local marina (who I am familiar with a trust) last year but the previous owner took them off the motor and took them in then reinstalled them himself. He also told me he messed with the screw on the controls below the tension bolt for the throttle. I realize the carbs are probably not adjusted right but my concern first is that the warm up lever barely moves and this may be a major reason the engine wont start without holding the butterflies open on the carbs and it wont idle but does run well above idle speed. The previous owner also assured me that the timing was not messed with becasue he didnt know how to check it. What I need to know is if anyone has had any experience with adjusting the warm up lever and how to adjust it. Could the warm up lever have anything to do with the motor not wanting to idle or start. Any help would be greatly appreciated. Thanks!
