57 Johnson loss of power
57johnsonmich
I have 57 johnson 7.5 hp...it seem to rev ok in nuetral but when I put it in gear it seems to only want to rev half way ..can only get about 2mph out of it....
Mas
Re: 57 Johnson loss of power
Sounds like you're fireing on one cylinder...check for spark!
Mas
HighTrim
You're coils, they're toasted eh!
kfa4303
Banned
+1. The coils were about the only weak spot on these old motors. The originals all fail in time. Thankflully, the new ones are 500000 times more reliable, so you should never have an issue with them again. These links will help you get the spark and other issues sorted out. You can get new coils, points and condensers, carb kits, etc... right here at iboats all for about $20 each. Holler if you get stuck.
http://www.marineengine.com/parts/v...evinrude-johnson/ITEM_2831/ITEM_283100001.htm (for erude of same year and hp. all part numbers should be the same)
http://www.outboard-boat-motor-repa...on 3 HP 1952-1967 Ignition System Tune-up.htm
http://www.duckworksmagazine.com/06/columns/max/index6.htm
